Wrong 5w20 oil and weird noises
#21
Originally Posted by thothtp' timestamp='1403228721' post='23210578
[quote name='iDomN8U' timestamp='1403222639' post='23210497']
If they put 5w20 in he engine imagine what they might have put in the diff
Change it out for a 70w90, 70w110 or of you track regularity 70w140 gl-5 diff oil
As I said in the OP, first thing I did was change the transmission and diff oils. It didn't change the noise at all.
[/quote]
Red Line synthetic gear oil 75w90 GL-5
#22
5w20 won't kill this engine unless you get the oil temps crazy high. In normal daily driving oil temps don't get high enough to make viscosity a concern. I would swap out the oil to the proper spec but 5w20 won't be responsible for creating engine noises. Dr. Haas from Bobistheoilguy.com runs a 5w20 in his Ferrari Enzo which specs a 40 weight oil, if you understand motor oil you won't have any concerns with a 5w20 in daily driving conditions.
#23
Is the sound (can't watch vid) the air intake? It just so happens that many OEM and aftermarket intakes make a high pitch sound when accelerating, especially between 2500-3500 RPMs.
#24
It's possible... though I would expect the pitch to change as the revs climbed? Also, it really sounds like its coming from behind me, though that could be an illusion.
