would there be problems putting in a f20c2 (euro) in a US car?
Now is the F20c2 in my car,
but i cant get it to start,
i am using my old (US ecm); and wire harness from the f20c2
The engine gets fuel, and sparks, and all the wires looked the same
It have started one time and run very badly
what could it be causing me problems?
It is no problem with the keys, tough i use the same ECM as before
Could it be that i need to use the UK ECM? i havent tried this yet because i need to reprogram the keys.
Now im using US ECM or should that mather at all?
[QUOTE]Originally posted by BosoS2k
When the engine started it ran on all 4 cylinders, so the sparks are there
yes i tried with the throttle plate open
Im going to leave the car to a Honda dealer tomorow for programm the keys
the engine worked fine when they removed it from the smashed car
Hi Simon,
I don't think the keys are the problem. Because you use the original (US) ECU with the original keys, this should take care of the immobilizer system by itself. I doubt the ECU 'knows' that there is a different engine installed in the vehicle.
Since it is a used engine the timing should be OK, so I'd focus on something else.
Did you reconnect everything properly? No small tubes mixed up? Did you make sure the ground cable is connected from the engine to the chassis (provided that there is one on our engines, honestly I don't know) for some reason this sticks in my mind as being a 'problem point'. All other connectors re-attached (MAP sensor, throttle position sensor, crank sensor etc. etc.)
It should just run fine!!!
Keep us posted and good luck!
Siepel
Siepel
The reason why i gonne get the keys programmed is that i will try a different ECM
I got it to start one more time, and i got an blinking CEL
I post the problem when i find it
The engine was from a crashed car, so there might be possible that the wire harness is damage...
