Worried about the burning smell.
I recently came back from WTD07 and noticed on the drive home that I was getting a burning smell inside the car. It's more noticeable when the top or the windows are down.
Now I think it's the clutch, but my only worries are that I changed the clutch last summer to a Stage 2 ACT along with the throw out bearing. I really hope that I don't have to replace it again, seeing that it hasn't been that long since the install.
I also notice a louder noise inside the car, down by the passenger side floor. It sounds like metal rubbing together. Any help would be appreciated.
I'm thinking the clutch is @#$ up,but I'm hoping maybe just maybe there's something else or a easy fix. It's not exactly the cheapest thing to repair, labor wise.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
Burning clutch smell is very distinctive. If you know someone mechanically inclined in your area, have them give a whiff to see what they think.
If you were at the Dragon, it may actually be your brakes!!![wink.gif](https://www.s2ki.com/forums/images/smilies/wink.gif)
Burning brake smell is different from clutch. So an experienced nose should be able to smell the difference.
![tongue.gif](https://www.s2ki.com/forums/images/smilies/tongue.gif)
Originally Posted by radtech,May 6 2009, 07:32 PM
The only thing though is that it smells all of the time as soon as I drive. I can't seeing it being the brakes. I will for sure take it too someone to have a smell.
If it smells like rubber, have you checked to see if you have a tire rubbing on an inner fender?
Thanks for the help, negcamber. There's no rubbing issues and the brakes seem to be fine. I would definately be looking elsewhere but the fact is I am getting that unusual sound inside the car. It's more noticeable when you rev the car. So that's why I'm thinking the clutch. I'll get it checked out.
i had a similar problem with a pick-up i had a few years ago, turned out it a was a broken spring in the clutch pressure plate. good luck to you, but thats where i would start looking
I'd first get a second opinion on the smell. Otherwise you might pull the clutch all the way out when your problem was a stuck caliper.
