Wont start when engine is hot?
Hey Guys, I recently bought a 99 white s2000, i have changed a few things like oil, plugs, timing chain tensioner, and removed an apexi neo that was wired in really wrong, the car is still not running right. there is no vtec!! it drives but very low on power, when i pull up to traffic lights its nearly cuts out and when i get back to the house after a little drive when engine is hot, turn off engine and it just cranks for about 10 seconds and then starts , sometimes it doesn't even start??? I have no clue what to do?
Any help would be greatly appreciated!!!!
the mods on the car are
Full Mugen Exhaust System
Spoon ECU
Bilstein Coilovers
and strut bars and stuff.
I disconnected a Defi controller and apexi neo that was plugged in because they weren't working properly, the apexi says i was doing 240kms when i was rolling in my garden at about 2-3km?????
the defi was just beeping constantly!?
I would really appreciate any help????
Spoon ECU
Bilstein Coilovers
Did you have to re connect any wires on the ecu or was the apex'i unit plug and play? IF someone hacked the apex'i unit into the factory harness id be looking there to make sure all the wires are connected properly..
What else would cause it to run like this?
I was also getting engine check light before when that apexi was wired in, but no check light now???
when the apexi was wired in , engine check light would turn on at around 6000revs .????
Funtimefrankie
08-17-2012 12:25 AM
