Won't shift
#21
So I was driving the car today and I found out it only has trouble shifting when the car has been running for a while, but when the car cools down or its cold it'll shift just fine.
#22
Just a thought...
#26
Hmmm really sounds like you got air in the lines then. When you bled it, did you remove the slave from the car, and point the bleeder straight up in the air? Did you gravity bleed it?
#27
#28
Try it Billman's way as I described, let us know if that helps. 1/4" clear fuel hose is your friend. For the record I've never gotten all the air out of the line by pumping the clutch. Gravity bleed is the way to go.
