Wont run with a pcv valve
Allright i thought my pcv was clogged and I had to order a new one. So for the time being i just drilled mine out it made it idle weird and it stumbled sometimes but it didnt die when i put the clutch in. Today i went and picked up my new pcv and put it on. Now every time i drive and come to a stop and push the clutch in it dies. I can start it back up and it will idle fine and drive fine but it does the same thing every stop... Im thinking Iac but not sure help please.!!!! Iv double and triple checked all vacume lines Im pretty sure its a sensor....
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Originally Posted by Burgman,Aug 18 2008, 08:58 PM
Sounds like a Idle Air Control valve is not working properly. The PCV valve should not effect the idle speed.
![iagree.gif](https://www.s2ki.com/forums/images/smilies/iagree.gif)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Originally Posted by Avionics86,Aug 19 2008, 05:40 PM
Disconnect the battery for a few minutes.
dan_bourne
05-29-2012 03:22 PM
