wont pass 7
Old 05-30-2007, 06:32 PM
Hectorious's Avatar
Arrow wont pass 7
hey my 2000, S2000 wont pass 7 thousand RPMS Why is that? its sopose to go to 9 thousand rpms right? i dont know if this is normal or not for this year s2k
Old 05-30-2007, 06:47 PM
FISH22's Avatar
are you letting the car warm up?
Old 05-30-2007, 06:52 PM
RedY2KS2k's Avatar
My '00 S2000 regularly revs above 7k rpm.
Old 05-30-2007, 07:05 PM
dead-bird's Avatar
3 bars on the temp guage, or it's no VTEC for you...
Could be the low temp rev limiter...
Old 05-30-2007, 07:17 PM
mxt_77's Avatar
I think low-temp limiter is closer to 6K.
Any CEL (Check Engine Light)? If not, try unplugging the MAP sensor and plugging it back in securely.
https://www.s2ki.com/forums/index.php?showtopic=209708
Also, since you're new here, I highly recommend reading this thread to see what other useful information can be found here:
https://www.s2ki.com/forums/index.php?showtopic=108435
It's the FAQs thread, and is a sticky at the top of this forum. Good stuff in there, and if you read it, I'll never have to use this smiley on you:
Old 05-31-2007, 05:16 AM
90crvtec's Avatar
It wasn't until 2001 that Honda enabled the 9000RPM redline, earlier cars redline at 7000RPM even though your tach reads up to 9000RPM. Just get a red sharpie and color in your new redline at 7000RPM, problem solved.
Old 05-31-2007, 09:22 AM
Money2536's Avatar
Now that's funny.
Old 05-31-2007, 09:24 AM
stphotographer's Avatar
It won't rev pas 7k at all even in neutral? or just in gear?
Have you checked under your gas pedal for any obstructions. I know it sounds stupid but the floor mat bunched up under the gas pedal of my Evo and I could not accelerate pas 5k for a while
Old 05-31-2007, 09:59 AM
s2k_redhead's Avatar
Hmmm, not sure I agree with this. I had a MY 2000 and it definitely ran up to 9k before hitting the rev limiter.
Old 05-31-2007, 10:12 AM
blackout's Avatar
I would check to see if there are any pending codes that arent throwing a light. This could be causing an early rev limiter
Quick Reply: wont pass 7
