won't go into gear at all
#22
Was doing some more research and it cam be possibly be the shift fork also... any input on how that could be the problem also?? Amd how much doea the slave cylinder suppose to push the fork in?? Mine barely moves half an inch...
#24
ouch man, i had an issue with replacing my new mc, was stickin alittle, byt after i adjusted it to a higher engagement point plus cleanin that slave rod and greasin helped out as well. glad u found the issue
#25
Clutch life is 100% on the driver.
I have an S2000 coming in for its first clutch next week, it has 220,000 on the original clutch.
Also have a customer that went through two clutches in 20k, learning to drive manual.
#28
How did you check about the disc? Did you pull the transmission yourself? I'm limited on funds, so I am trying to do all the work myself since I've pretty much blown a decent chunk of a clutch kit in CMC/SMC parts ><
#29
I am having a similar problem. Car just all of the sudden would not go into gear, bled the system and the car was drivable, but not the same. replaced the mc, still the same. replace the sc, still the same. Replaced the clutch line, still the same.
At first, it seemed like a hydraulic issue for me, but then yesterday when we were changing the clutch line, it started making a high pitch think sound.
back story, before i could feel the clutch let out higher the more i drove it. Let it cool, and it would be back to normal. Driving it one day, and went to shift to 2nd and it wouldn't go in. finally got it into a gear and it was super hard to shift. pedal actually went to the floor twice, but then got the pedal back. Also started having this weird shake when I would pull out, and the pedal had a LOT more vibrations coming through it. GOing to go ahead and order a clutch and see whats wrong and just replace the TOB and clutch.
#30
Well i didnt mention this but how this happen was from running my car really hard then it shit on me.. its just didnt happen out of no where.. and yea GTIWV that was the symtom i had before i did a last run and it exploded..
