won't go into gear at all
Okay this just happen earlier n I really need help asap... my tranny been acting up with going into gear really hard n now its just dead.. won't shift into gear and when I try to or force it in, the car dies like I stall... the clutch pedal is completely soft n wierd feeling like its sticking... fluid is good in clutch resevoir. Don't know about tranny but should be good..
Look underneath the dash and follow the clutch pedal mechanism to the firewall, look for a leak. Sometimes the MC leaks from the back. The slave usually leaks behind the rubber cover in the trans so you cant see it.
if it was the clutch going out, you would be able to freely go into gear without stepping on the clutch, its more than likely the master cylinder seal went and no pressure is being pushed down to te slave or fork, check for tar color like or any sort of wetness around the cylinder's plunger right behind the clutch pedal
Thanks thanks thanks!!!! Yes there is a ugly leak by the clutch pedal.... and the fluid in the resevior is really black n dirty... ima change it out soon.. but i got a quick question. Do i have to do a gravity bleed or do i just pump it out by pressing onto the clutch multiple times??
EDIT: found a great DIY for you man: https://www.s2ki.com/s2000/topic/993...ravity-method/
