wont get into gears the right way
i checked the clutch master cylinder and seems perfect with normal fluid level. also when i press down the clutch pedal when car is on the clutch pedal starts to vibrate really bad, and when the gear start to engage it makes like a scrapping noise or squeeky around my firewall area
if it goes into gear with the car off it's not the transmission. its the clutch that's burnt out or anything related to the clutch assembly. pressure plate, bearing etc. bleed and check pressure in clutch hydraulics.
donkeykong
01-11-2007 11:59 AM
