Wobbling Rear Wheel
just cause Im trying to get any other possible idea.(i cant feel what hes talking about...about the treads being higher than others)....so if it is this,,is there no cure?.would just driving make it even out or anything?..or would an alignment help out possibly?.thnks
Originally Posted by Ludedude,Oct 7 2005, 01:19 PM
Why don't you believe your mechanic when he said "scalloped tire?"
i can Barely notice the scalloped heights of treads..honestly..but when u had it,,how Exactly did it feel when u rollin at a slower speed?.i want to know if its the same feeling as mine...thanks
(and what did u do about it by the way?..tires were as good as garbage or wat?)thnk u
1. What is wobbling here, the tire or the rim?
2. Is the wobble radial (in and out radially), or side-to-side? One wobble per revolution, or several per revolution?
3. Scalloping is typically caused by play somewhere in the system - wheel bearing, ball joint, etc.
