wiring diagram for radiator fans
I am going to hard wire my fans to a toggle inside the car. I just wanted to know if anyone had a picture of their wired setup or a diagram of the wires themselves.
In words:
Main fuse # 41, 100A
Fuse # 57 feeds the fan itself via a relay.
From relay to fan is Blue/Black, from fan to ground G201 is Black.
The power for the relays (more than 1) is coming from the IG2 relay, Yellow wire, the relays themselves are fused with fuse # 20, 7,5 A, after the fuse the wire is Black/Yellow.
A Green wire from the ECU switches the fan relay and the airco condensor fan relay.
I can't find a connector # but it looks like the same connector where the MAP sensor is in (Green/White - Green/Red - Yellow/Red)
I hope this helps.
I hope this helps.
