wiring boost controller
hi am wiring my boost controller today i need some 12v constant.
Can i wire it into the wiring harness and if so which wire is it?
And can i wire something else onto it also like a turbo timer.
Thanks for the replies ahead of time.
If you need a 12v under the hood, use the battery. If you need it under the dash than just use the fuse box. There are three empty pins on the left side of your fuse box and constant is the middle one.
am going to use this thread as a picture
i need it under the dash btw
https://www.s2ki.com/forums/index.php?showt...0&#entry7239920
where on the first pic can i splice in my wire?
i just went out to my car looks like some kinda male side of a conector
where do i get the female plug to stick in there because stickin a wire in there wont work
are there any female conectors that came with my car that i dont know about?
thanks again viper and ex-eclipse
sorry to revive an old thread, but the question is made easier to understand using the pic in this thread,
I want to install some defi gauges. I have wire for the ctsc esm that is using the ignition slot. Can I just tap into the existing wire for the two gauges or look else where?
