wire tuck help with alt and starter wires
Ive almost completed my wire tuck as well as battery relocation, ive also decided to remove my passenger airbag and tuck the large engine bay fuse box in that space and tucked the smaller engine bay fuse box inside of the fender.i am assuming the smaller fuse box powers the starter and the larger fuse box powers the alternator.and now im trying to figure out if there is a way to run one power wire from the smaller fuse box to carry power to both starter and alternator without having to run a power wire out of the larger fuse box now located under my passenger airbag cover on the dash.im currently using 0gauge wire from the trunk where the battery is now located to a distribution block where ive used 4gauge wire to connect to the large fuse box under the airbag cover.ive used another 4gauge wire from the distribution block to the smaller fuse box in the fender and intended on running a 4gauge wire from the smaller fuse box to the alternator and then jumping the connection from the alternator to the starter.any help or information would be well appreciated thank you
To impress some stranger in a parking lot on Friday night.......
Pulling the passenger airbag and risking the life of anyone who rides with him to impress someone with tucked wiring is not something I'd recommend.......a person's life is worth more than that......
Originally Posted by SheDrivesIt' timestamp='1396456553' post='23093487
Begs the question, "why has he done all this?"
I too have done a wire tuck. It was an awful decision. It looks nice but not worth the headache.
The airbag idea is a horrible one. Not worth risking injury to someone in an accident.
No one rides passenger in my vehicle. And ive done this all because I love building custom cars and fabrication, im not going to knock what someone else is passionate about.I wanted something different point blank.and specifically I want to know if I can run a power wire from the larger fuse box to the starter directly then jump to the alternator or do I have to run the power wire from the smaller fuse box where I came from originally?
run power wire from battery to starter. run power wire from alternator to battery. if u moved battery to trunk, do not run power from alt to fuse box, go battery to fuse box. if u do from alt to fuse box, the alt will not charge the battery well and the engine electric will take all the alt power. the little fuse box you were talking about for the starter i deleted. air pump power and eps power goes through that also. i deleted air pump crap and ran the power eps wire from battery and added my own 70 amp fuse holder.
