Windshield Washers Not Working
Hi Everyone,
I've had my S2k for about 2 months now and I haven't been able to get the windshield washers to work. I hear the pump working, but no fluid comes out. I have checked that the hose is attached. Any other thoughts or ideas?
Thanks!
Thanks!
Received 1,744 Likes
Remove hose from nozzles and then see if you can get the fluid to flow.
Try removing the existing fluid and then try adding vinegar to decalcify things. Once it works, replace fluid.
May also try adding a drop of vinegar to the nozzles themselves to see if they are blocked. You can remove them and ultrasonically clean them.
Is it just me, or are the windshield wipers just about the worst thing about the S2k?
Nope. The worst are the sun visors.
The following 2 users liked this post by cosmomiller:
rpg51 (09-14-2020),
windhund116 (09-14-2020)
I find that if I lower the top edge of the sunvisor so it it pointing at the bridge of my nose I can sometimes reduce the glare enough to peer ahead into the setting sun for a moment or two.
jimreaper
Jacksonville
47
09-18-2016 02:35 AM
Leviisbigred
08-28-2016 07:17 PM
RacerZook
08-04-2016 11:32 AM
