Window Thumps
Window Thumps
Help with drivers side window. After the battery went out, the driver side window started acting weird.
The window reaches the top and bottom of the window's range quite forcibly. You can feel it "thump" as it hits the max range. Doesn't do this on the passenger side.
Mine does that too. When I roll it up all the way, it sounds like it is hitting something hard. But I just learned to deal with it, it's been fine so far
Sent from my iPhone using Tapatalk
Maybe the window is loose? Mine is pretty shaky when I roll it all the way down. I'll see if I can find the problem this weekend on mine if I have time and we'll see if that works for you too! (:
