Wilwood brake pad question
I have the Wilwood 6 piston kit. When installing the brake pads with the shims, do I need to put grease between the shim and brake pad? It came with Wolverine shims with an adhesive back, so I was not sure if that was supposed to replace the grease or not. If I do need to, what kind of grease? Thanks
![revto9k.gif](https://www.s2ki.com/forums/images/smilies/revto9k.gif)
