Wilwood Brake kits
Old 02-22-2007, 03:41 PM
  #21
paulzale's Avatar
Originally Posted by CrazyPhuD,Feb 22 2007, 02:44 AM
Actually the RSX kit wouldn't fit the S2000 front brakes. The problem is in the Hat, it's Hub diameter is too small it's designed for the RSX which has a 64mm centerbore while the s2000 has a 70.1 centerbore up front. The hole in the hat of the RSX kit would be too small for the s2000.
I have seen these kits for the RSX for less than $700 shipped with braided lines. Are you sure the hats bore is too small? If so wouldn't it be easy for a machine shop to increase the bore or have the vendor do it? I also wouldn't be surprised if the center bore wasn't already larger.
Old 02-22-2007, 06:27 PM
  #22
CrazyPhuD's Avatar
Here's the listing of the RSX kit check the pdf...
http://www.wilwood.com/BrakeKits/Pages/07/index.asp
The hat that's used in the kit is...
170-6947
looking for that hat here....
http://www.wilwood.com/Products/003-...GTSF/index.asp
you can see the Inner Diamter hole of the hat is 2.53" which is 64.262mm. The front hub on the RSX is 64.1mm the front hub on the s2000 is 70.1mm. The hole just isn't big enough. I'm sure you could make it fit but do you really want to?
Old 02-23-2007, 01:06 AM
  #23
grantedS2k's Avatar
[QUOTE=CrazyPhuD,Feb 22 2007, 10:44 AM] Actually the RSX kit wouldn't fit the S2000 front brakes.
Old 02-23-2007, 02:48 AM
  #24
paulzale's Avatar
Great thanks, I like the costs of the Wilwood kit and seems like we are close!
Old 02-23-2007, 10:25 AM
  #25
CrazyPhuD's Avatar
Originally Posted by grantedS2k,Feb 23 2007, 02:06 AM
You're absolutely right, well spotted!
I think you are talking about the Centre Hole Diameter? For the S2000 thats 70,3mm or 2.75".
That means the correct hat from the list would be 170-8589, as it matches the PCD of 5 x 4.50" (5 x 114,3mm), and is the closest patch to the CHD.
More research to follow, I will crack this bitch and find a 100% compatible kit!
Be careful it has a hat offset of 1.05" compared to the .72" offset of the RSX kits. This would put the rotor .33"(8mm) inward which would likely not mesh with the brackets in the kit.
check out the hat diagrams
If it were me and I had no options I'd probably take the RSX hat and have it bored out to 70.1mm by a machine shop. But since there is a kit that's made for the s2k and it's not hugely more expensive(I don't know about VAT issues) than the RSX kit is it worth it?
Old 02-23-2007, 10:43 AM
  #26
Partshelper's Avatar
[QUOTE=CrazyPhuD,Feb 22 2007, 02:44 AM] Actually the RSX kit wouldn't fit the S2000 front brakes.
Old 02-23-2007, 10:46 AM
  #27
paulzale's Avatar
I would be interested depending on price, but I am here in the US.
Old 02-23-2007, 10:52 AM
  #28
Here is a link to the group buy that is currently available on these kits for the s2000
Group Buy Thread
Old 02-23-2007, 12:58 PM
  #29
AusS2000's Avatar
Actually an Aus/UK GB might be nice. There is currently a similar discussion going on in the Aus forum about brake upgrades.
Old 02-23-2007, 01:09 PM
  #30
Yeah I can do something for you guys. Let me know what you have in mind.. I am actually working on lowering the price for the kits. Shoud have some news soon
Quick Reply: Wilwood Brake kits
