Will race fuel help power/tq in stock s2000?
#21
Originally Posted by RACER,Apr 9 2006, 08:19 PM
This goes both ways.
You put a theory forward, the onus is on you to prove it or back off. I guess it also MIGHT make monkeys fly out your butt. Can you disprove it? There are enough bullsh!t forums out there full of misinformation without making this another one. I bet they'd appreciate Stito's membership fees.
And there is nothing lighthearted about blatantly calling someone a wanker. It's rude, insulting and a personal attack which is against the rules of this forum. Call someone a wanker where I come from and you'll be smiling through broken teeth.
#22
Before you are going to that track event check the throttle cable slack and adjust it if necessary
Do a search for "throttle cable slack" to read about it
IF adjustment is needed you WILL find a better throttle response at $0 cost (IF you can do it yourself)
fixed a typo
fixed a typo
#23
Originally Posted by AusS2000,Apr 9 2006, 07:51 AM
Don't be daft. If you had to disprove every cockamammy theory put forward by ignorant punters you'd never get anything done. Do I have to prove that Mugen oil filters don't improve throttle response just because I know that they don't? If someone believes in santa do I have to perform a complete aerial scan of the North Pole before I say I don't?
#24
Well it will defenitly add power if you going to add it into a stock car. What's going to happen is that if you put close to 110 octane in your car your going to burn up your stock CAT. This will give you a free flowing CAT which will increase throtle response(Yes I said "will"), and perform pretty much like a test pipe which we all know gives good gains to an S(far more then just adding n exhaust).
#25
On topic. This was done 4 years ago. We saw 16 horsepower returned that otherwise would be lost to the ECU retarding the timing. Is a big benefit in that way.
You must reset the ECU or the old retards will remain. Without the reset it will take a tank or two to get the max benefit.
My stock S with 91 octane 222rwhp. My stock S with 100 octane and ECU reset 238 rwhp. My stock S with 100 octane and a Mugen ECU (that likes octane) gave 241 rwhp same day.
Higher octane can have an effect.
#26
You theorys are incorrect .
100+ oct does not burn hotter it actually burns cooler . The reason why cats get destroyed is because race gas and aviation fuel are leaded . They do make a 99oct unleaded that they sell around the track here.
On most cars you can actually lose power as it is harder to ignite race fuel . Like stated earlier the BTU level of 87 is higher than say 93 . High oct fuel is only there to prevent detonation or preignition, It is not a power adder . If you have a car that is retarding the timing because of preignition then you would see benefits in higher oct.
Things that cause the ecu to retard timing .
Knock ( which can caused by the item below )
Air temp .
poor fuel or to low Octane
coolant temps
To hot of sparkplug
Hot spots created by over fueling and carbon deposits on the pistons and valves.
Hot oil getting past the rings
If you want to try fuel , Just stick with the VP 99 unleaded . It should help you run more consistent as we know the S doesn't like being heat soaked. Don't expect any miracles .
Sideways showed benefits , We are not sure what all the variables are all we know is he said stock . Was the ECU reset for the first runs on 91 ? Also he would see more gains than say me on the eastcoast as we have 93 on tap as our premium unleaded . Would he have seen the same gains at say 93 or 95 ?Sideways I know you said you did this years ago but do you by chance have the OBD logs of the pull to see what the ECU was actually doing ( I would be interested in a look ) ? We have seen different power output just by switching fuel brands . Different formulas do burn differently .
This is not intended as a argument just as a thought and a correction to some beliefs . Do as you will with it
Back to rule # 1 , you engine is a air pump .
#27
#28
Keep in mind AusS200, not everyone is as smart and intelligent as you are.
Maybe Stito shouldn't have called you a wanker, but does that give you the right to call him ignorant, stupid and to belittle him? Two wrongs do not make a right.
Your supposed to be a community organizer but you go around belittling people and making threatening comments
#30
The person you originally quoted said "maybe"
This is just plain dumb.
[QUOTE]Of course you wouldn't have to perform a complete aerial scan of the North Pole.
