Will crank and sometimes start lol
#22
Intake cam sprocket pin split, seizing the sprocket in a position that was slightly off. I should be able to change the cam and sprocket and the car should start right up.
The following 2 users liked this post by cedo:
noodels (02-17-2024),
windhund116 (02-17-2024)
#23
#24
#25
windhund116 (02-29-2024)
#26
RolanTHUNDER (03-05-2024)
#27
I suspect an offset wood ruff key timing adjustment modification failure..
it may have marking on it ?
#28
Those were the original cams that were on the block that threw a rod. I’m think mid high rev engine locked up and broke the pin. And I’ve also read oil starvation from a dirty vtec screen. But I’m glad I found it. Just got cams in and now I’m running into a different issue. Where the #1 cam cap just snapped. if anyone has any clue on how to deal with this without changing the head on my newly built engine that would be great
#29
That may need line boring,have you another to put in ?
Have you checked for bent camshaft ?
#30
