Will AP2 DIFFERENTIAL FIT ON AP1
Billman as long as you're on here.....I swapped out an ap1 for an ap2 diff. I also swapped out the matching prop shaft for the new dif. I noticed that not only are the flanges different, but the entire prop shaft was redesigned. Is the prop shaft matched and balanced to the diff at the factory? Are you better off swapping both?
I'm assuming the larger flange and propshaft redesign is to take stress off the front of the diff housing?
Thanks
fltsfshr
Thanks
fltsfshr
Thanks
fltsfshr
Thanks
fltsfshr
I could have sent you the trans flange but, I just sent it to someone else You can buy a new one from Honda for about $35.00
Originally Posted by jyeung528,May 15 2007, 01:39 PM
ap2 is reinforced...
Search is one thing, but than there is always the FAQ stuck at the top of this forum. This thread is posted there that addresses this question in part.
MY01, MY04 and CompTech diffs, Photos showing the differance
The FAQ link is here.
FAQ's, DIYs, and Maintenance!, Please click here first!
RockinDave
11-25-2008 01:45 PM
