Will A AP1 cluster fit on AP2
Old 08-27-2007, 04:09 PM
s2krey's Avatar
Thumbs up Will A AP1 cluster fit on AP2
Just wondering if a AP1 cluster will fit a AP2 and everything else work. I know that the rpm will not go to 9k and other things Ap1 related.
I need to know if they hook up directly and the Gas,temp etc will work the same.
I just need a plain YES or NO.
Thanks!
Old 08-27-2007, 04:22 PM
Banned
ElGringoLoco's Avatar
Looks as if they have the same connections on the back so I'd walk out on limb and say yes.
Old 08-27-2007, 06:41 PM
Stratocaster's Avatar
They use a differant wairing harness and connectors. So fit it will. But you wil have to change the wire harness.
Old 08-27-2007, 08:34 PM
s2krey's Avatar
is this an easy thing to do to swap harnesses?
Old 08-28-2007, 08:04 AM
s2krey's Avatar
bump
Old 08-28-2007, 01:33 PM
Remove the dash, swap harness. It is a lot of work, but hard no, I don't think so.
Old 08-28-2007, 06:16 PM
gdmlaz's Avatar
grrrr i was thinkin to do the same
Old 08-28-2007, 06:20 PM
GrandMasterKhan's Avatar
so if you swap the harness by removing the dash is it plug and play?
Are the harness connections INSIDE the car? or do you have to pull the harness through the firewall etc?
Old 08-28-2007, 06:51 PM
SOHCmyDOHC's Avatar
It's an underdash harness. LOT's of wires!
Old 08-28-2007, 07:13 PM
Killship's Avatar
If I ever see you with an AP1 cluster, Im going to rev higher than you... Poser
Quick Reply: Will A AP1 cluster fit on AP2
