Will an aftermarket clutch cure the decel buzz?
Originally Posted by otb2000itr,Sep 16 2004, 08:13 PM
"the buzz usually comes back, so why do you want us to fix it...?"
I have heard that the buzzing is caused by the springs on the friction disk. The MY01 and the MY03 have the same part # listed for the PP, but different part #'s for the friction disk. The part # for the MY01 friction disk is 22200-PCX-045. The MY03 is 22200-PCX-055.
It makes me wonder why there are two different part #'s if the disk has been updated (improved)
Originally Posted by F20C1pwr,Sep 16 2004, 10:37 PM
I have a CM Stage 3 Carbon/Kevlar clutch and a Spoon Flywheel and I still have the buzzing issue. The car drives 100 times better so I just deal with the noise or keep out of that rpm range.
So thats what that dang buzzing is, sounds like something is rattling under the shifter....god its annoying and only under deacceleration...i usually take is out of gear when I deaccelerate because of it...
Good to know that its fixable and what it is..
thanks everyone
thanks everyone
Originally Posted by hecash,Sep 17 2004, 07:15 AM
The clutch that Honda replaced my original with started buzzing after about 2000 miles.
this is why
If you look on the upper right hand corner, you will see it is dated Nov, 27th 2001.
You did not get the updated disk. Part number 22200-PCX-055 is the updated disk that you did not get. I have absolutely no problemo's with my clutch
Honda has taken care of the clutch buzz.
Eqlize
03-19-2003 09:26 PM
