Will an aftermarket clutch cure the decel buzz?
The Honda dealership is giving me a hard time as I suspected they would about the buzz under deceleration, so from reading the TSB, all Honda does is replace the clutch disc to cure it. If I upgrade the clutch disc and pressure plate to an ACT or Clutchmasters, can I expect the same results...?
Good suggestion as far as the components go, but it doesn't answer my question. If I go to an aftermarket clutch, can I expect the buzz under deceleration to disappear...? Because apparently it's an issue with the clutch design....
Originally Posted by vodalus,Sep 16 2004, 04:18 PM
My original disc was replaced under warranty for the rattle and the new, updated, one also began to rattle after a few thousand miles.
i just installed an exedy stage 2 clutch and upgraded the flywheel to a fidanza lightweight aluminum one and i hear no buzzing and it shifts 100% better than stock....i highly suggest upgrading the clutch/flywheel!
As much as you don't want to hear this many after market clutches will still make the buzzing noise. The best thing to do would be start a poll and ask people about the different clutches you are looking at to see if they have the buzzing on there setup. I have a CM Stage 3 Carbon/Kevlar clutch and a Spoon Flywheel and I still have the buzzing issue. The car drives 100 times better so I just deal with the noise or keep out of that rpm range. Hope that helps.
