Wideband install
Old 06-19-2007, 11:26 AM
TheCarGuy2021's Avatar
Default Wideband install
Hey all, I'm just curious if there is any way to remove the secondary O2 sensor (any way to wire it up?) so that it will not throw a CEL. I would like to put my wideband O2 sensor in the secondary O2 sensor bung on my test pipe.
Old 06-19-2007, 11:33 AM
Johnny Sack's Avatar
why dont you just take your test pipe to a muffler shop and have them weld a bung for a secondary o2?
Old 06-19-2007, 11:38 AM
I figure if the secondary O2 sensor is already useless (backed out of exhaust flow) then why not use it's bung for the wideband. It would be cheaper and easier as well. I figure I would ask anyway before I go get another bung welded on.
Old 06-19-2007, 11:48 AM
but then youd never have to fiddle with the factory o2 and then you could hook up a wideband and have a AFR meter right in the car so you could keep an eye on AFRs.
its really just one less o2 sensor you have to worry about stripping.
Old 06-19-2007, 11:52 AM
MB
Member
MB's Avatar
Do what I did and buy a PLX - it replaces the primary o2 sensor but it has a 0-1 v signal wire which you can hook into the ECU, instead of the stock one. The PLX sends a simulated narrowband signal to the ECU, to the car actually knows no different.
I'd go so far to say that mine was smoother with it in place.
Click on my S/C link for more info.
Or you can put in a fixed resistor into the secondary sensor circuit and just unplug the sensor, and put your WB in there.
Old 06-19-2007, 11:54 AM
I already have an AEM wideband UEGO.
Old 06-19-2007, 11:55 AM
Good point versionJDM...
Old 06-19-2007, 11:58 AM
Old 06-19-2007, 12:11 PM
Just got back from a local welder, estimate of $80 and he said he wouldn't do it after all because the bung isn't stainless....
Old 06-19-2007, 12:15 PM
thats odd. mine isnt stainless(afterall its just a glorifed nut) and my local welder did it no prob. as long as its proper heat treated metal its not really going to matter.
Quick Reply: Wideband install
