why replace the oil jet banjo bolts?
Old 05-10-2011, 01:57 PM
erikvanden's Avatar
Default why replace the oil jet banjo bolts?
I know people frequently replace the oil jet banjo bolts but why? Is their something wrong with the stock ones? I am FI should I be worried?
There are lots of threads about replacing them but I haven't been able to find one that stated why.
Old 05-10-2011, 02:31 PM
AusS2000's Avatar
The early ones don't flow enough oil. Mid-2002 ones onwards have 4 holes rather than 2.
Old 05-10-2011, 02:39 PM
steven975's Avatar
If you are FI, definitely do it.
Old 05-10-2011, 02:41 PM
suzuka-blue-s2k's Avatar
People with the older ones tend to get scorred cylinder walls easier due to the banjo bolts.
Old 05-10-2011, 03:25 PM
erikvanden's Avatar
Is this a lubrication problem or a cooling problem?
Also, where could I get the jet bolts from? the install doesn't seem that difficult and I am sure I could do it some time over the next few months.
Old 05-10-2011, 03:32 PM
Any dealership should have them, just make sure you get them for an 03 or up (mid 02's got them but not all of them). Hardtopguy also has them on his site. It's a lubrication problem, it doesnt flow enough oil and the cylinder pretty much overheats from the friction and causes scoring on the walls. I had to replace my shortblock already due to a scorred wall and it's not fun or cheap! My new block had them in but I think cylinder 1 will be a PITA because the oil pump and stuff is in the way.
Old 05-10-2011, 05:20 PM
erikvanden's Avatar
would it really be that bad? Don't you just jack up the car, drain the oil, take the pan off, and replace the bolts?
They seem fairly easy to get at.
How can you tell if you have scored walls?
and can't you just remove the oil pump?
Old 05-10-2011, 06:14 PM
ahrmike's Avatar
i got all the bolts but I havent tackled this yet. Not looking forward to it.. Id rather do my clutch again then this
Old 05-10-2011, 06:29 PM
s20009k's Avatar
how can you tell if you have it or not if your 2002?
Old 05-10-2011, 06:34 PM
dammitjim's Avatar
02 engines with serial numbers higher than #1025386 should have the new ones
https://www.s2ki.com/s2000/topic/102...nstall-w-pics/
Quick Reply: why replace the oil jet banjo bolts?
