Why are intake valves larger than exhaust?
Originally Posted by S2oooNvegas,Jan 11 2005, 10:38 PM
well, nitrogen (76% of the air you breathe) is at a high content in there, and cannot be burnt. all you have left is some carbon monoxide, (partially burnt hydrocarbons) and some Co2 (byproduct of combustion) and water.
Originally Posted by Sideways,Jan 12 2005, 12:45 PM
Larger exhaust valves also have problems with heat.
It's easier to get exhaust out than it is to get air/fuel mixture in, isn't it?
More to the point, why would you have a smaller intake valve? If it can't get in, why would it need to get out?
Originally Posted by steven975,Jan 12 2005, 10:04 AM
also the exhaust gasses are "pumped" out with positive pressure (the piston going up) while the intake gasses fill the void of a low pressure area inside the cylinder.
After a series of rather silly posts no_really has got it right.
There is a lot more volume after combustion than before, but it is being pumped out. The only thing driving air in is atmospheric pressure (talking NA here) and as there are plenty of restrictions between the air filter and the port you want to make it as easy as possible for air/fuel to get in to the combustion chamber.
