Why I do my own work...
#21
Originally Posted by Dark_Sub_Rosa,Aug 7 2004, 01:45 AM
nobody listened to me when I said it was good
Now, the jury is till out in my book, so if it turns out that GMSFM causes a problem, are you gonna pay the deamage claims? Can't have it both ways, chief.
#22
Hmmm...was looking around to buy some GM synchromesh and i noticed a post on Honda-tech stating that there was a fully synthetic version of it for NV4500 trannies...
http://honda-tech.com/zerothread?id=...ostid=10756590
General Motors (Part #12346190)
Chrysler (Part #4637579)
I also found a link suggesting that the proper replacement for this with redline products is a 50/50 mix of MTL/MT-90....interesting.......
http://www.hrpworld.com/client_images/ecom...eader/488_1.pdf
anyone heard of this?
Skeptical at this point but curious........I think this is titled GM's Synthetic MTF....
Edit:.....another discussion I've found on this MTF.....still trying process everything...
http://www.turbodieselregister.com/forums/...topic/1237.html
#23
Do not mix RL Mt-90 and MTL. Gernby didn't like it and that is good enough for me. It broke down very fast-not sure if there was any damage done. This 'blend' might work for some applications, as not all transmissions are created equal.
I have put ~750 street miles (to date) on the GMSFM. Honestly, it feels like MT-90 with a tad less notchiness. I think the original GMS, without the FM, was actually smoother though it didn't have the desired longevity. Time will tell with the GMSFM.
RR, incidentally, I had a bad valve cover seal, leaking catch can and drain valve. I feel these contributed to my oddly excessive oil consumption that I complianed to you about. All leaks are now fixed, and I have only lost one diamond on the dipstick after 1000 miles of 10w-30 Amsoil.
I will see how it fairs in more inclement situations
#24
#25
My issues are with heat. Under hot conditions, some fluids grind more due to how their viscosities change with heat. To date, (from the current offerings) MT-90 wins in this department. I will be testing this in 100 degree desert temperatures with 20-30 mins of 9K rpm shifting. We will see what happens. I may just give up on fluids and rig a tranny cooler with a thermostat.
At this point, I think the FM is inferior to the non-FM synchromesh. Just my opinion from street driving in the last couple of weeks.
editted for grammar
editted for grammar
#26
Two more possible source solutons for GMSMFM: Caddy dealers and transmission repair specialty shops.
I got mine from the latter and he knew all about the difference.
Regards,
BD
Regards,
BD
MaxGeek
15
11-11-2005 10:43 AM
