Why Is Driving Through Snow Bad for Braking?
Old 02-14-2010, 03:20 PM
laurensdejong's Avatar
Originally, I had discarded the water surface theory because the brake degradation would stay for 20 minutes or so; even brushing the rotors helped only temporarily. Now that it's been discussed here, I realize that the melting snow and ice keeps dumping water onto the rotor, and as long as that happens, I have to keep brushing the rotor or just be ready for degraded braking. Thanks for the discussion, guys; although I don't understand if slotted rotors would truly help.
Old 02-14-2010, 03:21 PM
Originally Posted by SpitfireS,Feb 14 2010, 01:09 AM
Think about this: how cold is that top when you close it?
I don't think my top is one of those that can actually open or close.
Old 02-14-2010, 08:52 PM
GTS Jeff's Avatar
The whole point of slots is to wipe the braking surface clean of debris. Debris can be anything from to dirt to water to snow.
Old 02-15-2010, 11:22 AM
moe6's Avatar
Perhaps you should find out how disc brakes actually work.
http://auto.howstuffworks.com/auto-parts/b.../disc-brake.htm
Old 02-15-2010, 05:06 PM
slackfaster's Avatar
your tires might just be cold...
cold rubber (ambient temp plus the snow/slush = damn cold rubber) is too hard to stick to pavement...
After a while of running on pavement the temp should rise a little --- but summer tires (and/or most high speed rated rubber) and snow are a big no no
tigerfan
12-04-2003 11:49 AM
Destiny2002
12-12-2002 04:16 PM
Quick Reply: Why Is Driving Through Snow Bad for Braking?
