why does vortech make a seperate kit for the 2003?
#23
I would say that he got it here:
For Immediate Release
2003 Honda S2000 Supercharging System
Channel Islands, CA (September 19, 2003)-Vortech Engineering, LLC has introduced a new supercharging system for the 2003 Honda S2000.
The addition of the V-2 SQ SC-Trim supercharger will increase horsepower from 240 to 358 and torque from 153 lb./ft. to 214 lb./ft. at 7-8 psig at the flywheel.**
The system includes an integrated dual-pass air/water charge cooling configuration, which features a closed loop water cooling system with a stand-alone pump, tank and front mounted heat exchanger. All components needed to bolt the system to a stock vehicle, such as billet aluminum mounting bracket, fuel system upgrade includes replacement injectors and high-flow fuel pump, supercharger oil feed and drain, Maxflow Racing compressor bypass valve and all required fasteners are included. The installation allows retention of all factory accessories including A/C and power steering. This system is available in satin or polished finish and is 50-state smog legal under CARB EO #D-213-21. The V-2 supercharger is covered by a three-year limited warranty.
**Supercharged horsepower and torque data shown is a calculated estimate based on percentage increases from actual rear wheel hp/tq measurements.
Part # 4HS218-010SQ 2000-2003 Honda S2000 (satin) Suggested Retail Price: $5,243.95
Part # 4HS218-018SQ 2000-2003 Honda S2000 (polished) Suggested Retail Price: $5,508.95
#30
So if the kit is exactly the same as the one for 00-02 only with injectors can we use this 03 kit with 00-02. And when is someone going to put a supercharger on a 04
