Who doesn't love some engine carnage in the morning?
Old 10-19-2016, 12:22 PM
MorngWoodStewie's Avatar
I think a good note to be taken as well is the scorching seems to get worse from cyl 2 an back all the way to 4.
Hmm.
Old 10-19-2016, 01:36 PM
tozerman's Avatar
I cannot believe that people are still having problems due to starvation/low oil level. for crying out loud!!
How can you buy one of these cars and not be aware of this issue?
Anyway rant over and feeling your pain mate....
Old 10-19-2016, 08:26 PM
Curious on the cam wheel bolt cause, an1 care to explain?
Old 10-19-2016, 08:28 PM
I understand the point. Just how would it starve the top end?
Old 10-20-2016, 08:52 AM
Billman250's Avatar
Received 1,338 Likes on 810 Posts
The camwheel is the end of the line for top end oil pressure. If it becomes loose, all pressure bleeds out from behind it.
Old 10-20-2016, 07:08 PM
Car Analogy's Avatar
Received 1,385 Likes on 1,037 Posts
This is that bolt you can see in the middle of the head, below the valve cover, at the front of motor. Everyone should check the torque on this bolt on their car. Cheap insurance.
The torque spec is....to be posted in a new post since can't edit posts...
Old 10-20-2016, 07:12 PM
...36 ft/lbs. Go check it. Everyone.
Old 10-21-2016, 01:59 AM
Xeon's Avatar
Most of the time if this bolt is lose it will leak oil
Old 10-21-2016, 04:44 AM
Slowcrash_101's Avatar
No not really, usually the o-ring will leak from age.
Old 10-21-2016, 07:38 PM
Billman250's Avatar
Xeon if that bolt is loose your engine is junk in seconds. Loose will not cause leaks.
Quick Reply: Who doesn't love some engine carnage in the morning?
