White Spark Plug tips
My car has been misfiring, the exhaust makes a weird noise and the engine seems like it shakes randomly on idle. When I try to reverse out, it kinda sounds like a motorcycle. I checked the spark plugs and the tips are white on all four of them. The coil packs are fine and changed them no more than 15k miles ago. My friend suggested that it could be clogged/faulty fuel injectors but I'm not sure. The idle is rough and I can definitely hear weird popping/misfiring noises when I stand by exhaust. I checked for exhaust leaks and nothing either. That friend said I could be running lean due to the bad fuel injectors. I'm pretty sure they are the OEM ones and I'm currently sitting at 151k miles. I put 91 from Chevron and not long ago, I had fixed some incorrect vac lines. Filled my tank with some Techron and car seemed to be running perfect until recently where the stuttering/whatever it could possibly be has started up again. I checked my timing and it was spot on and chain is tensioned on TDC so I've ruled out spark, coils, and timing.
What could possibly make my car sound like that? Could I be running lean due to faulty injectors and has shown on the white tip of the spark plugs?
Link to the sound:
Link to the sound:
When did you last adjust the valve lash?
I doubt that is your issue as it would be very rare to have 4 clogged injectors. You can get a misfire from injectors or coils, coils are probably more common but you can test for them easily. "White" plugs can be normal, do you have pictures of the plugs ?
Plugs look pretty normal , those are newer plugs correct ? They are burning really clean, white is normal for part throttle driving which is stoich a/f ratio, if you were doing a lot of WOT driving they would be a bit darker over time.
You can run a bottle of Redline fuel system cleaner for good measure but I think your bogging issue is something else.
What could it be then? I don't know if you can tell by the video but it's so weird and boggs on idle and when I take off in 1st. Should I double check valve adjustment? if that's good, what can be causing it? bad o2 sensor? go ahead and check the injectors? I've ran Techron fuel system cleaner twice within a week and it keeps coming back. it went away after I resetted the ECU but now it's back and that took about a week and a half.
Link to the sound:
https://youtu.be/DHH_ysFnIOU
Link to the sound:
-- Chuck
windhund116 (01-15-2021)
