White smoke out of exhaust?
Well in light of this cali summer weather, i washed the S and the went out for a drive on the twisties with two of my friends with bikes. Well about half way through our drive, white smoke starts bellowing out of my exhaust. I am almost positive this was just water from the wash goin in my PRM, but............. does anything else create white smoke? Water going in the intake at that high of temperature i would assume would just evaporate and not do any damage to the piston right? thanks for the insight
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
If you were doing sustained high-g turns (left turns I think) and your oil level is high or a little overfull, you can get burning oil (white smoke). Happened to me once but now I have oil changes down to a science.
Its normal, especially on my 01 b/c the ECU dumps fuel into the motor during VTEC.. Im not sure about the 03 ECU though. And if it was just a minute amount of water, it would actually clean your engine.
A catch can in your future I see young Jedi.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
Originally Posted by awbritton,May 18 2006, 09:38 PM
On a previous car, I had a cracked head gasket that was causing coolant to get into the pistons and resulted in white smoke with a faint smell of coolant.
Those who have head gasket failures are running lots of boost, different head studs, and thicker gaskets.
