white smoke
white smoke
my car is smoking alittle bit.its weird when you first start it theres no smoke then about a minute later theres some smoke but then after a little drive i stop the car and check and the smoke is gone.any ideas???i was thinking maybe i had to much oil but the oil looks just right.
is it a little smoke? do you store your car outside over night?
if so it sounds normal.
are you using any antifreeze? does the exh have a sweet smell to it?
no that question is not a joke.
Do you have a catalytic converter? Aftermarket exhaust of any kind?
I get some considerable white smoke on cool mornings, particularly if I run the car for a bit, then stop (or idle) then run again. Mine is from condensation building up in the pipe and then getting steamed out when the exhaust heats up.
Originally Posted by YellowS2kPwr,Oct 26 2005, 04:43 PM
As far as I know white smoke=burning oil
White smoke = water vapor (possibly coolant)
Blue smoke = oil
Black smoke = fuel
