Whistling?
Old 04-08-2009, 10:44 PM
oyitzpreston's Avatar
Default Whistling?
my car has been whistling for about a couple of months now and i cant stand it anymore. It only happens when give it gas between 0-45 once i hit highway speeds its either gone or i cant hear it. It sounds like its in my cabin so i thought it was my AC so i starting flipping switches still whistles. I checked to see if it was just the wind but its not. No idea WT*... is this whistle noise can anyone help me out?
Old 04-08-2009, 10:45 PM
SgtB's Avatar
Do you have an aftermarket intake? Most cars whistle when the throttle plate is at a certain angle. The plate is thin.
Old 04-09-2009, 02:50 AM
Olegator's Avatar
turbo? ..... passenger side window?
Old 04-09-2009, 04:32 AM
MeFryRice's Avatar
Do you still have the factory intake? If so, did you remove the airbox cover?
Old 04-09-2009, 04:45 AM
HS2K007's Avatar
could be coming throught the audio system. If you have an amp or new radio. Turn the volume up or down as you here it. If it changes the volume of sound, you need an isolator on the power wire or you have a bad ground connection.
Old 04-09-2009, 06:31 AM
i have a K&N FIPK and i have an after market radio and my components are amped up i check both of these right now
Old 04-09-2009, 07:04 AM
Eric220's Avatar
VTAAAAAAK
Old 04-09-2009, 07:16 AM
txchopper5's Avatar
Probably the intake dude, but i'd be happy to ride with you sometime and see if we can figure it out
Old 04-09-2009, 09:00 AM
DSCLegend's Avatar
bad ground on the amps
Old 04-09-2009, 09:20 AM
it does it randomly imma have to wait for it to do it again
Quick Reply: Whistling?
