Whirling Noise from the Diff...
Torsen application PDF
We are in good company
Why change a Torque Sensing diff for a fixed clutch type?
Originally Posted by Race Miata,Jun 1 2006, 02:48 PM
...but usually when it breaks, it's the ring and pinion gears and housing. Nothing to do with the Torsen itself. You'll still have to replace the ring and pinion gears and housing. And you'll be replacing a healthy Torsen with a clutch-type LSD.
as for the "why a clutch type?" question i feel that an adjustable clutch type could be fun to have rather than a fixed torsen.
Potential problem with factory LSDs (whether Torsen or clutch-type) is that they can be not aggressive enough. Most factory LSDs run no preload and relatively low max lockup. Preload is good for smoother lockup. IOW, it's not the change from Torsen to clutch-type that improves performance. It's the aggressive nature of aftermarket LSD that helps.
Originally Posted by jzz30,Jun 2 2006, 03:24 PM
yea thats why i would want to change to clutch type and an adjustable one so that i can adjust to my liking
i dont know if there is one available for the S but for the Z and G35 the Nismo diff is adjustable. you just need to take one side of the axle off and insert a wrench and clickit to your liking. one of our costomers has this and i just thought that there should be one available for the S also if there is one for the Z. do you know of any?
