whining, humming sound from differential?
i did a burn out like 2 days ago and after that there's a humming sound from the differential i think. i have 4.56gears and i don't think it was as loud as now. what do you think happened?
Well if it sounds different, then you've probably gotten a "pwnd!!1! Diff"
Was it reinforced?
Apparently you haven't asked anyone to help diagnose it, that should be your first step. A bunch of guys 100's of miles away can't give you an answer with the info provided.
Try getting a friend to help determine where the sound is coming from.
If you determine it's the Diff.
Change your Fluid and see if you have any metal chunks.
Was it reinforced?
VisualEchos
04-20-2002 06:56 PM
