Where is the "rear steering joint bolt?"
Hey, i'm trying to install my clutch and I am following a DIY, and it says to remove the "rear steering joint bolt." Where is that located? If you have any pics or could describe where it is? Thanks.
There's a rubber boot on the steering shaft, which is beside the AC compressor. You'll likely need to get at it from under the car, as the picture below shows. Push that boot up losen the bolts on the coupler so that you can disconnect the steering shaft from the steering rack.
Alpine Jay
01-12-2017 07:28 AM
GreenLightGo
09-20-2016 08:48 PM
AquilaEagle
03-28-2015 11:56 AM
