Where to install a second coolant temp sensor?
The drain bolt is hidden above the motor mount bracket. It has to be drilled an tapped for the temp sender.
Mine is drilled and tapped for 1/8 NPT
I'd still use the modifry gauge fix with the EMS as well.
I think i will drill and tap it to M10x1.
Thank you very much slows2k.
Found this, http://www.racinglab.com/greddy-hose-adapter.html
Not sure about the threads for the sensor though.
