Where to get OEM parts?
Just picked up a 01' S2000. It needs a valve-cover gasket, its leaking. I'd also like to get a fuel filter, spark plug, and air filter to tune it up. Idk about Honda's but a tune on my unreliable BMW takes 4-O2 Sensors, Air Filter, Fuel Filter, MAF Sensor, Spark Plugs, Camshaft Position Sensors, and Manifold gaskets. I'd like to do something similar, since its already at 96k miles. Is there a source for OEM parts for the S2000? Unfortunately, I don't know the OEM Manufacturers like I do BMWs. So what manufacturer is the OEM supplier for Valve-Cover Gasket? I'm assuming Bosch is the O2 sensor supplier and NGKs are for the plugs. Any information will help!
P.S - I also am replacing the clutch. Should I replace the rear main seal at this time?
Amazon carries the plugs for our car...NGK platinum, heat range 7. I do have a set with 3K on them...I went for colder iridiums since I have a supercharger.
http://www.amazon.com/NGK-PFR7G-11S-...2002&carId=001
I use Majestic for pretty much everything, though.
