Where are fuel lines routed
I am wanting to bolt an emanage behind the driver seat and need to drill a couple holes for the bolts. I am pretty sure I am in a safe spot and as far as I can tell there is nothing exceptsheet metal where I am drilling.
But I am concerned because I have no idea how the fuel lines are routed from the tank to the engine and want to stay well away from them. DOes anybody know where the fuel lines run, I can seem to see them anywhere.
Originally Posted by jphish,May 25 2009, 01:33 PM
They are above the left rear strut mount.
Originally Posted by vader1,May 25 2009, 02:04 PM
Thanks, but from there how do they travel to the engine? I am just trying to determine if they ever cross behind the seat and run up the transmission tunnel so that I don't drill into them. Isee where the fuel line comes up from below the engine into the fuel rail, and I know where they go leaving the tank. Its the in between part I am not so sure about.
Thanks. That part coincides with the slight hump under the drivers seat. I was just about to put a self tapping screw in there. You just saved me a trip to the burn unit.
ScienceofSpeed
08-04-2014 06:35 PM
