Where to find lost horses
We dynoed two S2000s 4 years ago on the same conservative Mustang dyno within minutes of each other. My buddy's pure stock 2002 peaked at about 205 wheel HP and my Gernby FlashPro tuned 2006 peaked at 221 whp. Have no idea how that translates to engine HP. The power curves were significantly different with much more power under the curve on the 2006. Both cars were running K&N FIPK intakes, Berk high flow cats, and Tanabe Medalion Turing exhausts. Dyno numbers aside he described my car as "a beast" in comparison to his.
What's your FlashPro VTEC? Who did the tune? A 3600rpm VTEC dramatically improves acceleration, so much that I added an audible red-line alarm to stop bumping the rev limiter. No pre-tune dyno data but you have yours.
-- Chuck
-- Chuck
The HFC is going to make the most difference as you have seen. Then probably the header. If you DONT have an HFC and tune it with VTEC set at 4400 you will have a severe dip in power around 3500 rpm.
Also note that you will not feel VTEC engage tuned that way. When it comes in lower in the band, it is very subtle and much more linear than stock, which gives some the impression something is wrong since they do not feel it engage like it did at 6000 rpm.
130k miles, if you haven't had a VA done already, you're valves are likely burnt. The spec is 100k miles, and Billman has warned to do it MUCH sooner on dbw cars.
I did mine soon as his warning came out, which was around 85k miles for me, still well below the 100k spec, so I thought I still had a ways to go.
But I found several tight exhaust valves, one at .003! A few at like .007 and another at .005. not cool. My compression wasn't too bad. Must have caught it just in time. Still, I'm expecting issues eventually and need to pull head sooner than otherwise .
Do it asap!
Do it asap!
The VA is a legitimate job for the health of the engine but I'm not following the OP's thinking that the car is producing less than it should. Most gains from a tune and HFC seem to be in the mid-range. Maybe it is as @engifineer pointed out, that the lowered VTEC point is making it seem not as strong? I mean, what is the rationale behind the engine has "lost" power exactly? A TV show and an isolated low peak dyno #?
I believe the 2002 car in my earlier note had a aftermarket exhaust header on it as there was some sort of builder plate visible. May explain 205 rather than 195 whp. (Been 4 years!).
Anyway, I doubt our cars lose measurable power unless the engine is abnormally worn. Also I note Wheeler Dealers is/was heavily scripted so I don't draw any generalities from it. Not seen it in a couple of years as it became pretty non-relevant after the phony S2000 episode confirmed the scripting.
-- Chuck
How long has the engine been tuned on Flashpro? The running lean issue is only there if stock/modded without a tune. So if the mods/tune were recent with no valve adjustments that you know of, I'd definitely get that done ASAP. I found out the hard way (compression on #2 was 20 PSI lower than the rest). Your header was designed for midrange gains, not top end. What type of dyno did you use?
She ran calling Wildfire...
Thomas Guide
02-09-2018 02:54 PM
