Where do I connect pressure sender for boost gauge?
Originally posted by Reignman
There is only one screw to attach a wire on so Im guessing I will also attach a ground wire to that screw. Would that work if I had the wire running to the gauge and the ground wire coming off the same place?
You must somehow attache a small wire to where the sender's threads would be. It looks like in your pic, where that brass colored fitting screws into the bottom of the sender. Wrap some bare wire tightly around that base and tape it solidly with electrical tape. Then the other end must be attached to a solid ground bolt on the engine - like maybe that one to the far left in your pic. Do a test fit by just taking a wire and just tape it to those places to see if that "activates" your gauge. Since it will read zero when the car is off, you'll have to start the car. If it's working, you should see "vacuum" at idle (about -10 psi). If this works, then you need to make more solid connections.
Dangit. I reconnected the sender to the place you guys said and still nothing. Can you guys see anything that could be wrong with it?
Let me know about the red/blue hose !! What happened to the fuel regulator ? Is this an replacement part ?
Yeah Wesmaster I saw your post before where you posted a pic showing where it connected but the image on the post isnt there anymore. To make it easier here is a picture of my engine. Does the sender need to connect to A, B, or C or is it another hose?
Thanks
Thanks
RT,
I thought I had removed all I needed for the check valve. there was a small white valve off of the MAP sensor and I removed that. Do I also need to remove the tube going to the MAP sensor?
Yeah, get rid of the block under the MAP (you're going to need the stock short screws back) and the tubing all the way back to the "Y" near the rear of the intake manifold (remove the "Y" too).
scs2000
10-04-2002 12:53 PM
