Where is Connector "A" pin #15 on the ECU
Hi there.
I need to know where is the connector A pin 15 on the 2002 ECU.
Or does any one have the diagram on the ECU pins? Please let me know.
Thanks
Thanks
This reference is for the "Wire side of the female terminal" This is also for a 2001 car but it should be the same for an '02 check wire color/function to be sure:
The 15 pin drives the fuel pump relay and is green and yellow in color. Looking at the connector... count left to right 4 acrossin the top row. The forth wire in this row should be Lt Grn/Wht. The wire directly below it is the 15 pin (grn/ylw).
Hope this helps,
Utah
Hope this helps,
Utah
lotus7racer
08-13-2008 04:55 PM
