when to replace rotors
Old 10-24-2014, 11:45 PM
  #21
Soviet's Avatar
Originally Posted by DallasAp1
Do you have a micrometer?
Front
Brake Disc Thickness:
Standard 24.9-25.1 mm (0.98-0.99 in.)
Max. Refinishing Limit 23.0 mm (0.91 in.)
Brake Disc parallelism 0.015 mm (0.0006 in.) max
Rear
Standard 11.9-12.1 mm (0.469-0.476 in.)
Max. Refinishing Limit 10mm (0.39) in.)
Brake Disc Parallelism 0.015 mm (0.0006 in.)
so less than 23mm 0.91 in. on the front is trash
and less than 10mm 0.39 in. on the rear is trash
Perfect info. I was measuring my rotors today and thought 25 was on the low end but I was wrong!
Old 10-25-2014, 04:16 AM
  #22
redlineracing's Avatar
I upgrading mine at first pad change ( approx 80k).I went with EBC slots,Goodridge SS lines and Hawk HPS pads.It's a good DD setup for me.
\rlr
Carolina
Old 10-25-2014, 05:22 AM
  #23
deepbluejh's Avatar
At 95k miles my fronts were down to 23.5mm (not sure what the rears were at). I had developed a rotor "wobble" under braking, plus the rotor hats had gotten rusty, so I decided it was time to upgrade to Stoptech slotted sport rotors. So far a great upgrade for me.
Old 10-26-2014, 05:15 PM
  #24
Yaupon's Avatar
thank you...helpful information.
Front
Rear
Old 10-26-2014, 07:47 PM
  #25
windhund116's Avatar
Received 1,529 Likes on 1,033 Posts
What is the latest skinny on carbon-ceramic discs, for track use? Much better than OEM? Heat range? Wear?
Danke!
http://www.brembo.com/en/car/origina...c%20discs.aspx
Old 10-27-2014, 06:26 AM
  #26
deepbluejh's Avatar
Danke!
http://www.brembo.co...ic%20discs.aspx
AFAIK, you cannot get a carbon ceramic brake system for this car, period.
Old 10-27-2014, 12:18 PM
  #27
Slowcrash_101's Avatar
The only benefit carbon ceramic rotors have over conventional iron rotors is heat tolerance, which is a non issue provided the rotors have proper ventilation. They're not lighter, nor do they give better braking performance than adequately vented iron rotors.
CTMechE
05-18-2015 12:40 PM
jtsimaras
12-23-2012 08:21 PM
ebchu
05-07-2012 07:33 AM
Shazzam
05-21-2011 07:05 AM
RareWhiteS2k
01-06-2006 06:19 AM
Quick Reply: when to replace rotors
