Wheels stud have broken 3 times in the last 4wks
Old 09-14-2006, 06:45 PM
Wildncrazy's Avatar
He's disappeared.
Maybe he realized it was his rims.
Old 09-14-2006, 06:50 PM
bakeram21's Avatar
actually i did rotate my tires....that could be it what do u guys think? by the way theyre stock rims and i torqued them to 80 psi....let me keep hearing from u guys...thanks
Old 09-14-2006, 06:57 PM
Slows2k's Avatar
You just answered the question. The rear wheels are not the same hub center as the front wheels. They DO NOT fit on the front hubs. Rotate them back ASAP. This is your cause of the broken studs.
Psi is also not a torque reading Ft/lbs is.
Old 09-14-2006, 07:13 PM
Rusted_nailz's Avatar
s2000's have a stagger setup meaning the rear wheels/tires are wider. In addition, the hub size between front and rears is completely different. You need to put the wheels back ASAP. It is very dangerous thet way it is right now.
Old 09-14-2006, 07:14 PM
ShocK's Avatar
You cant rotate the rims period. I had tires installed on my stock rims and they missmatched the front and rear rims with the wrong tires and the rim wouldnt even go onto the hub. The inside diameter of the rear rim is too small to mount to the front hub. period.
Old 09-14-2006, 07:25 PM
mikegarrison's Avatar
Originally Posted by FISH22,Sep 14 2006, 04:22 PM
good question, if you have aftermarket wheels...if there are no hubcentric rings, that can be your problem.
Prove it. Most of the track guys run with no hubcentric rings and put a hell of a lot more stress on their wheels without any problems.
Old 09-14-2006, 07:27 PM
bakeram21's Avatar
Theres the answer...thanks alot guys....i couldnt have figured it out since im mechanically challenged i will change the wheels asap thanks again
Old 09-14-2006, 07:29 PM
But if you try and force it on, and then torque down the lugs, what will happen is that the wheel will wobble while you drive. When that happens, you almost immediately exceed the ultimate stress limit of the studs --> snap!
Old 09-14-2006, 09:13 PM
pantyraider's Avatar
It would be pretty obvious if you did somehting like that. You'd have to be an idiot to drive around with wobbling wheels.
Old 09-14-2006, 09:35 PM
darkfx's Avatar
but somehow the OP did it!
Quick Reply: Wheels stud have broken 3 times in the last 4wks
