Wheel weights - true?
Hi,
I noticed my wheels have some weights in the rear lip (as opposed to the front lip) in addition to the adhesive-type weights in the rim itself. Is it ok to have the weights on the rear lip? The Honda service manual states the following: "The wheels on this model are not designed to mount the balance weight on the outer side of the wheel. Instead, mount the self-adhesive balance weight on the inner side of the wheels."
I've seen my Honda dealer mount clip-on weights on the lip that is on the inside surface (closest to the center of the vehicle), but never on the outside visible edge. It was in conjunction with adhesive weights being used on the interior surface of the rim, I think sometimes it can't be avoided if that is the only way to balance the wheel. I was fine with it being on that side of the wheel as long as it isn't on the outer visible edge. The two edges of the rim are different, the one edge will accept clip on weights, the other might not.
If it is an AP2V1 wheel then there should definitely NOT be standard hammer-on weights on the face of the wheel. Only on the inner lip. Tape-weights should be used along the inner edge towards the face of the wheel to balance.
Could you take a picture of the weights on the wheel for us? Because unless my memory serves me incorrectly, there is no lip for a standard wheel weight on the outer edge of an AP2v1 wheel...
S2000_UK
12-22-2006 09:17 AM
