Wheel Stud Replacement Cost FYI
Old 12-17-2007 | 11:02 PM
CarbonYellowJ's's Avatar
Default Wheel Stud Replacement Cost FYI
Hey guys. Ive seen some discussion on changing out wheel studs and I wanted to share my findings as I have two that were stripped by A STUPID BODYSHOP.
1.You cannot replace the studs without a press.
2.You cannot replace the studs without removing the knuckle
3.You should replace the wheel bearings and spindle nut when pressing out hub
4.You should use pickle forks to remove the knuckle
5.Replacement bearings can cost anywhere from 44 to 174 dollars depending on brand and shop. A good bearing(1) would cost 80-90 at a discount shop.
6.I was quoted 444 for the replacement of two studs(One side, non-stealership). Parts were 165 total.
Hope this helps anyone wondering about changing studs or getting normal spacers installed.
Old 12-18-2007 | 12:34 AM
crazyasnboy's Avatar
GO SPACERS!!
Old 12-18-2007 | 12:51 AM
NVMY4N's Avatar
4 threads on this in the FAQ/DIY Section
Old 12-18-2007 | 02:00 AM
yeah I know there are threads on this but none were concise or gave an exact estimate from a shop
Old 12-18-2007 | 05:06 AM
Slows2k's Avatar
You should NOT use a pickle fork unless you just really want to destroy a ball joint boot.
Old 12-18-2007 | 02:35 PM
ridestrt's Avatar
Yup you need a ball joint removal tool. There is a honda specific one also available but not worth all the extra money in my opinion.
Old 12-19-2007 | 04:54 AM
daktruckie99's Avatar
If it was stripped by a stupid bodyshop then the cost to you is 0.
I've had similar experiences in the past and it's never cost me a dime. Good luck
Old 12-19-2007 | 05:16 AM
jguerdat's Avatar
I had one replaced by the dealer - cost was $90, including parts.
Old 12-19-2007 | 02:40 PM
jdm knowledge's Avatar
A hub at Honda cost about 50 bucks and a bearing from them is around the same i believe. A machine shop should only charge about 60 bucks for the pair to press them in. 444 sounds a bit steep to me. I had it happen to me and i put in Skunk2 extended wheel studs.
Old 12-20-2007 | 08:32 PM
babowc's Avatar
why not just run bolt on spacers?
they make 15mm+ bolts ons.
unless you want to run <15mm?
jmortizjr
01-20-2014 03:28 PM
Roflcopter
08-22-2012 06:23 AM
S2k.berto
06-21-2011 10:07 AM
AFs2k
09-24-2010 10:31 PM
Amuse_AP1
08-09-2004 10:14 PM
