Wheel rusted to rotor - can not remove
Old 05-23-2007, 06:55 PM
  #21
Avionics86's Avatar
Take it to a tire place and ask for a rotation.
Old 05-23-2007, 07:22 PM
  #22
viets2k's Avatar
LOL....that's a great idea.
Several weeks ago i help ones of local member swapping the springs and both of his front wheels was stuck hard to the rotor and a BIG kick will do the trick.
Old 05-23-2007, 07:30 PM
  #23
SB2007's Avatar
Originally Posted by acurandy@aol.com,May 23 2007, 08:15 PM
If you manage to get the rim off, spray the hub with some white grease. This will prevent the rim from sticking next time. Make sure to wipe any overspray off the rotor. Good luck
Or antiseize lubricant on the back side of the wheel...
Old 05-23-2007, 07:39 PM
  #24
CaymanS2k's Avatar
i've had this same thing happen to me before years ago with my old rabbit. I had to use a torch and heat it up really good. ended up changing the wheel and rotor...but of course i upgraded all the rotors.
so yeah heat should do the job,
Old 05-24-2007, 12:12 PM
  #25
kfar09's Avatar
loosen the lug nuts, face away from the car, and give it a big hard donkey kick. should come loose then. just dont miss and kick the body panel. haha
Old 05-24-2007, 04:55 PM
  #26
jeggy's Avatar
why is everyone still telling this guy to kick it even when he said he drove it with the lugs on loosly around the block??? 3,000+ lbs wont break it loose but you all seem to think kicking it will help??
i agree with the "take it to a tire shop and ask for a rotation".
JohnnyRingo
11-15-2005 09:36 AM
simonprelude
06-01-2005 01:13 PM
Quick Reply: Wheel rusted to rotor - can not remove
