Wheel rusted to rotor - can not remove
Old 05-23-2007, 05:17 AM
hyper's Avatar
Originally Posted by S2Kdreamz,May 23 2007, 12:32 AM
In my experiences, I have just given the tire a good solid kick and it always comes loose.
yup, that worked well for me too.
but on my previous civic i had the same problem (salted roads in the winter + steel wheels w/ hubcaps) -- what I did was jack up the car, crawl under and try my best to spray the "back" of the wheel where it meets the hub w/ WD40 (not sure if PB blaster is better at anti-seizing as I've never heard of it) to a point where its soaked and left it overnight.
the next morning a couple of swift kick to the tires and the sucker finally came loose.
perhaps you have to let whatever you spray soak in for some time before it'll take effect.
good luck!
Old 05-23-2007, 05:20 AM
Mike in Atlanta's Avatar
Originally Posted by madcowdk,May 23 2007, 02:04 AM
has worked for me in the past.
X2
I couldn't get my rotors off of my Grand Cherokee. I used a LOT of PB Blaster, and beat it with a BFH to break it loose.
Old 05-23-2007, 05:48 AM
kamui157's Avatar
Kick the tire like it owed you money!
Old 05-23-2007, 05:55 AM
orangebarius's Avatar
make the lug nuts really loose and then jack up the car from the other side. this way all the weight of the car will be on that 1 wheel. if a few thousand pounds doesnt loosen it, then i dont know what will.
Old 05-23-2007, 11:13 AM
blackout's Avatar
swift kick like you are trying to destroy someones manhood usually does the trick.
Old 05-23-2007, 11:54 AM
tinkfist's Avatar
Originally Posted by kleecker,May 23 2007, 06:39 AM
I loosened the lug nuts several turns and DROVE the car locally. Nothing happened. So, I went out again, lug nuts still loose, and intentionally hit every bump and pot hole I could find (truck is old, and has seen much worse than that) - still did not un-freeze the wheel from the rotor.
Try doing some moves that put some lateral forces on those front wheels. Is there any place that you can get some leverage on the wheels to pry them off with a crowbar?
Old 05-23-2007, 12:45 PM
camuman's Avatar
i vote for the hulk strength kick to the tire. worked for me wiht my 2002 vw jetta.
another buddy drove around with the lugs barely tight and tht loosened it up. good luck.
Old 05-23-2007, 04:29 PM
SB2007's Avatar
That always worked for me
Old 05-23-2007, 04:33 PM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Big sledge on the rim, backed up with a piece of wood.
Old 05-23-2007, 05:15 PM
acurandy@aol.com's Avatar
If you manage to get the rim off, spray the hub with some white grease. This will prevent the rim from sticking next time. Make sure to wipe any overspray off the rotor. Good luck
Quick Reply: Wheel rusted to rotor - can not remove
